Comments not shown under comments but in issues changelog
JK
October 4, 2019
Hi all,
i found out that some comments in our Jira instance do not appear under "comments" but in the issue´s changelog. There seems no workflow action done. So I think it happened within the standard comment function.
Until now I was not able to reproduce that problem, but it is existent in our Jira 7.3 and even some database entries are from the time we had Jira 4.
I can find affected issue by searching the changeitem table with 'field' = 'Comment'. Field 'oldvalue' always stores the comment made and 'oldstring', 'newvalue', 'newstring' are empty.
Is that a known issue or has anybody the same problem? May it occur through a bad designed custom workflow transistion (but as I wrote above there is no one logged)?
Looking forward to your answers!
Jochen
JK
October 14, 2019
Can please anybody comment if their jira instance is affected by the same problem or not?
Select * from public.changeitem where field = 'Comment'
Gikku
Hi @JK
Is there any chance that you have a custom field of the same name 'Comment' and you are using that field instead of the system one in your screens. ?
JK
October 4, 2019
Hi @Gikku
Thanks for your answer. I haven´t checked that before, but there is no custom field 'Comment' existing in our system.
