Company-managed Software project
rtamam
Can an Administrator user (on a Company-managed Software project) can affect/change issue type for more projects that he's not even member of them?
By changing his project settings
2 accepted
Akhand Pratap Singh
Hello @rtamam
Hope you are doing good.
To answer your question, if by "Administrator user" you mean a Project Administrator, with no Global permission to administer Jira then no, they cannot.
However, if you're referring to a Jira System Administrator and the issue type scheme being edited is linked to multiple projects, then yes, it will have an impact.
rtamam
Sam Nadarajan
Hello @rtamam not that I am aware of. Project Administrators can only view the configurations available for their project, but they wouldn't have the authority to change the issue type scheme if it was shared across multiple projects.
Hope this Helps!
rtamam
