×Please help
Compare between two date custom fields condition and if true/false thn edit action field.
If duedate is greater than enddate
then edit action field should be true
If duedate is lesser than enddate
then edit action field should be false
If duedate is equal to enddate
Hi @Kiran Kumar
For a question like this please post an image of the complete rule and the audit log details showing the rule execution. Those will provide context for the community to offer suggestions.
Until we see those...
You are trying to compare data value using a text formatted version of the dates.
When doing that, particularly to test for less than / greater than relationships, always order the date components so they align with the testing. To do this, I recommend using the jiraDate format or "yyyy-MM-dd".
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/#Date-format---
Otherwise they will not "sort" in the order you expect.
Register Now
