I want to ask the following:
Can I assign issue to component lead at specific workflow statuses other than the initial status?
Can I restrict an issue to be transitioned to be limited to the component lead.
Can i limit number of subtasks that users can create under the parent issue to a specific subtask issue type? for example if i have Subtask 1 and Subtask 2, i want ti implement only 3 issues of Subtask 1 to be created under the parent issue, or to hide it from the dropdown list.
Assign issue Component Lead
Using Post Function, you can assign the issue to Component Lead at the time of transition.
Restrict issue transition
You can restrict who can transition the issue.
Limit number of subtasks
This can't be done natively in JIRA. You will have to use script runner or some marketplace app for this
Dear @Vishal Biyani
Thank you so much, i can't find the restrict transition to apply it on the component lead only, are you sure this is available?
Do you have a script that i can use in script runner to limit the number of subtasks??
Learn more
