Component picker alternative plugin?
Savvas Radevic
December 5, 2023
Hi do you know of a component picker plugin alternative for data center?
https://marketplace.atlassian.com/apps/1217020/component-picker
Thank you
Ste Wright
Hi @Savvas Radevic
Have you tried contacting the vendor of this App, to see if there's an alternative they recommend?
Not sure on the exact functionality you need, but there's Apps like...
Ste
Savvas Radevic
December 5, 2023
Thank you Ste. Already contacted their support, hopefully they reply with alternative. Thank you for the options I will check them out.
Like Ste Wright likes this
Deniz Oğuz - Starware
Configuration Management Toolkit has data center version and a "subcomponent field". It is visually different than build-in component picker, but it can display the components in the projects as a new field. JQL search also works.
Like Savvas Radevic likes this
