Condition for making no of Attachment mandatory in a specific transition in workflow.
siva
Is there any optional script that can be used to make
4 attachments mandatory at a specific transition in workflow of jira.
Will C
February 17, 2020
Use a simple scripted condition in a workflow post functions using scriptrunner and use the following code:
ComponentAccessor.attachmentManager.getAttachments(issue).size() >= 4
I am presuming this is what you want? this won't let you transition the issue unless there are 4 or more attachments attached to the current issue.
siva
@Will C  thank you
I had the Script for 4 or greater in an issue.
is there any option at a specific transition i 4 attachments ??
Will C
February 17, 2020
Sorry I don't understand your question? so you know there is 4 attachments at a specific transition in the workflow, what are you want to do now?
Daniel Ebers
February 17, 2020
Starting off here you could do some further actions based on ScriptRunner (please see here for further documentation: https://scriptrunner.adaptavist.com/5.6.15/jira/recipes/workflow/validators/validate-attachments-links-in-transition.html).
Daniel
siva
sorry ill elaborate,
when i make a transition, i have a pop up screen which requests for a attachment.
at that point i need to make a validator scritpt that if user doesnt attach 4 attachments.
the transition gives an error.
Will C
February 17, 2020
I understand what you want to do now, I am not sure if the pop up part of this is possible. it is possible to check for attachments and then put an error against a field when this isn't met, but the part with a pop up I am not sure of, maybe somebody from Adaptavist will be able to advise further.
Like siva likes this
Manoj
@Will C
@Daniel Ebers
Hello Both, Greetings!
is there any way to make attachment based on condition and moves the transition.
like i have a custom field is "Total Amount"
If the total Amount is >= 10000 then attachment is mandatory to attach.
and IF the total amount is <10000 then attachment is not required.
Kindly advice.
