Will the automation below in the attached work: I'm going over a list of tickets with different types. One is Questionnaire and the other is Deployment. According to the type I'm copying data to the parent.
Will the automation here continue on a Deployment task to the second stage after the If Questionnaire type failed?
If not - what should I be doing?
Hi @Dd
No your setup will not work the type doesn't equal Deployment the rule will stop.
You will need to use the IF/Else condition to make this work.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
