Dear all,
Is it possible to configure a screen to see "Issues in Epic" in preview? Now I have to "clik" in current Epic and scroll.
Hi Paulina,
This is a feature on Jira Software 8.14 and newer. What version are you using? You may also want to review your board configuration's issue detail view. Cheers!
@Joshua Sneed Contegix Thank you for responding. I work on Jira 8.8, so it is not possilble to have that view? Maybe some kind of custom field?
Welcome Paulina!
I just verified on JSW 8.13 that Issues in Epic does not appear on a board's issue detail view without the use of a plugin (e.g. Structure). We are currently UATing a dev upgrade to 8.20 where Issues in Epic does appear. The options to meet you request are a plugin or upgrade. Cheers!
