Configure Jira and Bitbucket Branching Model To GitFlow
Gal Segal December 14, 2013
I try to use Atlassian products across all development process. I chose GitFlow as a working flow on SourceTree, and aim to streamline it via Jira and Bitbucket as well.
Few things I would like to understand:
  1. Is there a way to configure the behavior of "create branch" on Jira to identify features/hotfixes/bugfixes and tell Bitbucket to open branches accordingly? (ie for a feature called XXX-123, open branch feature/XXX-123 from develop branch). As far as I see, Bitbucket opens a branch called XXX-123, but from master.
  2. Is there a way to close a branch after the issue has been closed? I see "create branch" button on closed issues.
Gal
Gal Segal December 26, 2013
Opened a request on the SourceTree repo.
Khaled AbuShqear February 22, 2022
any actual real documentation to setup this??
myTraderNET
August 30, 2020
I am not sure if this will help you.
the default develop branch to the project is master. You can change this.
1 open you project;
2 select repository setting at the bottom;
3 select branching model;
4 set development and produtinhos branch according.
Gal Segal December 20, 2013
Unfortunately, this is an issue needs to be resolved by the dev team of Atlassian.
I will be waiting and meanwhile do things manualy.
Timothy
December 14, 2013
Thanks for the sugestion... I know my way on git and this is not what I asked for. Since my team already use Jira and Bitbucket, and Atlassian offers integration between all its products, I wondered if there is a way to streamline development process, especially branching and merging, which is human error prone.
Timothy
December 15, 2013
For item 1, if the integration only opens a branch in master, then I guess you're stuck with that. I know that if you use Stash, it allows you to choose which branch you want to create it on.
Gal Segal December 15, 2013
Thanks for that. I know stash supports it better than Bitbucket. If you look at the URL in Bitbucket, after you click the "create branch" on Jira, you can see it has "IssueType=Feature" in the query string, but Bitbucket ignore it.
I think it can be better if you define the Bitbucket repo to use GitFlow and use this info to create the equivalent branch.
