Configure Navigation
Maahshid Vaziri
Hi all
I recently add lots of plugins in my Jira, and now navigation bar looks messy also create button was hidden, can I customise or configure navigation bar with my taste?
Thanks for help in advanced
Fabian Lim
Hi @Maahshid Vaziri
I agree with you.  Once you have a lot of plugins the navigation bar looks very messy.  Some vendors allow you to hide them, but there is not much you can do if they don't have the hide/show feature.
Cheers
Maahshid Vaziri
April 29, 2023 edited
@Fabian Lim @Thanks and how can I bring back Create button in navbar?
Also, Can you suggest any add on to fix this problem? I really need it, I can't work like this...
I appreciate it, if you explain more about hide/show options as you said before.
Fabian Lim
if you are a sys admin you will need to go to the third party application's configurations and see if there are options to hide it.   I
Your issue may be a browser issue? Can you share a screenshot to see what your nav bar looks like?
Maahshid Vaziri
Capture.PNG Here you are, and I want to add an issue search in the navigation bar too, but I don't know how. many thanks for your help.
