Is it possible to define a particular board (Kanban or Scrum) as your homepage? When I define boards as my homepage in my profile settings, the wrong board is shown. How can a particular board defined as the homepage?
Hi @T_ Gök
@Florian Bonniec is correct the last board you used on a project will be where you will return.
This is stored in your profile related cookie.
