I try to configure a issue view JIRA Cloud but the new version doesn't have the Issue Detail View tab.
I used following documentation.
Are you enrolled onto JIRA Labs? If so, they are currently testing the new detailed issue view. If you would like to return to the original view simply switch off your enrolment to JIRA Labs.
You can do this by navigating to a board, select any issue so the new issue view appears, select the 3 dots in the top right corner of the screen and choose the option: Turn off new issue view.
Hope this helps
Is there any way to set this off state for all users?
