Configuring the issue detail view - Jira cloud
PGA
August 23, 2018
Hello everybody!
I have troubles with the new view of Jira.
Please take a look at the attached picture.
The story description and the story title on the right side, should be in the left area i think. Its nearly impossible to work this way.
Can someone explain how to configure the view, so that the view is displayed correctly.
Syauqi
August 23, 2018
Hi Pierre,
I'm afraid it is not possible to change the location of the custom field as the new popup issue view isn't customisable. We do have an existing bug report opened which you can track here: Option to configure Issue Detail View in board in JIRA new layout. Though we don't have any ETA when this will get fixed. Please keep a watch on the ticket to be notified of any changes
Syauqi
Patrick Poulin
What is the default configuration for the new issue view ... ?
In my case the view shows some of my custom fields but it's completely  useless if I can manage field order. The old view is more effective.
Like • adrian.wood likes this
Syauqi
September 25, 2018
To better understand the issue, could you share to us an example type of custom field that is showing on that new issue view? Looking into our bug/feature request there's a couple of ticket raised related to this:
Select List (cascading) custom field isn't showing on new issue view
Custom field does not appear in Agile board issue detail modal/popup
Patrick Poulin
ex : I create many custom fields for tool migration purpose. But all those CF are useless for my jira user.  But in the new issue view, all those CF are shown at the top of the view ?!?! I need to order field on this view and select only field applicable to my current board.
