Conflict add on with Tempo 7.14.1.1
Treethawat Thanawachiramate
Currently we're testing aip plugin on our JIRA test environment. We've found that the aip plugin has conflicted with tempo pluig. The 'Worklog Calendar' view will show a blank page but if we uninstall the aip plugin the 'Worklog Calendar' will work fine.
Other issue with drop down menus on a project navigation page, you can test it by:
  • Click the 'Project -> Select any projects' on a JIRA dashboard
  • Then click "dashboards" or "projects" or "issues" or "agile" drop down menu. They won't show anything except a empty gray box.
  • It will be working fine if we uninstall Tempo or AIP plugin.
AIP Version: 2.2
JIRA Platform: JIRA Server
JIRA Version: 6.4.12
Tempo Version: 7.14.1.1
Could you please help?
Man
Flying Agile
October 20, 2015
Hi All,
we have fixed the conflict with Tempo Timesheets in Agile Issue Printer 2.2.1. Please try it and let us know whether it works for you.
Cheers, FA
Thanks! we'll test it and let you know.
It's working good with the version 2.2.1. Thanks!!!
Eric Almquist
To add a little more information, AIP 2.2 works fine with our old environment of JIRA 6.3.15 and Tempo Timesheets 7.13.2.
Axel David Ingolfsson
October 22, 2015
Hi Treethawat and Flying Agile.
My name is Axel and I am a developer on the Tempo Timesheets team.
I looked into the last thing you mentioned Treethawat and found out that this issue is actually our fault.
Here is a technical explanation of what's happening: The resize handlebar's size is measured in "em" but not in "px" on our worklogs which means that it depends on the font size that is set on that particualar div. AIP then ships a newer version of jQuery UI then what we're using and in that version the font size on the handlebar element is set to 0.1px which causes the handlebar to nearly dissappear. We will fix this and hopefully we will be able to include that fix in Timesheets 7.16 which should arrive around Summit (beginning of November).
Flying Agile: May I ask what was causing the original conflict, in case we can do something to prevent it on our side?
Axel.
Flying Agile
October 22, 2015
Hi Axel, thank you for your investigation concerning jQuery UI CSS. I hope this fix is simple for you. I think the original problem was caused by webpack used in both add-ons. AIP and TT were using the same window.webpackJsonp variable to load their modules. To fix it we have changed our webpack configuration. See https://webpack.github.io/docs/configuration.html#output-jsonpfunction Cheers, Flying Agile
October 23, 2015
Thank you Flying Agile for that information, it's definitely helpful for us. We will fix that on our side as well to make sure it doesn't happen again. Kind regards, Axel.
Hi Axel and Flying Agile, Thanks both of you to updated the question. I really appreciate your help. We'll wait for the next upgrade and let you guys know the result here. Regards, Man
Hi Flying Agile,
I've just found a new issue with AIP 2.2.1, in the tempo 'Worklog Calendar' view. We normally able to adjust our logged time by drag up or down the logged time windows. But this function won't be working if AIP is installed.
Could you please recheck with that?
Flying Agile
October 18, 2015
we do not know Tempo plug-in.
Can you please provide screen shots showing the problem ?
We would like to reproduce it.
Thanks, FA
Flying Agile
October 19, 2015
I have reproduced the problem and looking for root cause.
Eric Almquist
Thank you
Register now
