Copying Tasks in Jira Tempo
Kurt Bonheure
February 3, 2025
Up till today you could easily copy a task in Jira Temp by holding the CTRL-key and then dragging the task to the desired location.
Since this morning this does not work any longer and the task is moved instead of copied.
This makes the timesheet a real drag and triples the time needed to complete the timesheet in a decent way!
Is this a bug or has the feature for copying a task just gone?
Max Bauer
February 4, 2025 edited
We are experiencing the same issue - hoping for a fix!
Contemi-EUR_ Daniel Garton
February 4, 2025
I have just tried and ALT + drag copies logs. I am not sure if this is permanent but I will use until it stops working.
Tested on Windows 10 + Firefox
Like • 3 people like this
Max Bauer
February 4, 2025
Can confirm, that works like CTRL in the past - thanks!
Like • Contemi-EUR_ Daniel Garton likes this
Andres Oss February 13, 2025
Why on earth was it changed and not notified properly? There should be some options/settings, that can be altered to modify it per user preference...
Erik van Dongen
February 9, 2025
Very annoying that this changed. Somehow this is muscle memory for me and I just keep ctrl-dragging
Erik van Dongen
February 13, 2025
I contacted Tempo support about it and they created a 'tempo idea': https://ideas.tempo.io/ideas/T-I-3224
Please upvote if you think we need ctrl-drag back!
Pedro Costa
February 4, 2025
I noticed on friday. It's still the same today. Really annoying.
