Confluence is failed to connect to Jira directory
김형준 [Vehicle System]
January 6, 2021
Dear all,
I executed Jira and Confluence as docker container on same server.
And I configured Application connected using OAuth.
On Jira, 2 accounts exist : admin, user-A
On Confluence, 1 account exists : admin
And I configured Jira User Server and added application:
password: **** (set)
IP address :
::1
127.0.0.1
10.113.81.48
And I tried to add User directory on Confluence, 404 Forbidden occurs
Directory : Atlassian Jira
Server URL : http://10.113.81.48:8080/
Application name : confluence
password: Same password on confluence Jira User Server setting.
I used latest version of Jira-Software, Confluence Server on dockerhub.
I can't find what is the problem.
I need your help.
Thank you
Artur Moura
January 6, 2021
Hi, @김형준 [Vehicle System]
It seems Jira and Confluence can't connect together, this usually happens when you create the containers, but you don't create the network for the containers, or you didn't export the ports to the docker host.
Additionally, you can refer to this https://confluence.atlassian.com/kb/application-links-troubleshooting-guide-718668765.html, article, which helps to troubleshoot the Application links.
Hope it helps.
SERVER
Register now
