Connection fields not filtered properly in Published Board View
Antoni Abella Vendrell
I've created a board view that uses the typical opportunity > solution hierarchy to show a product roadmap:
  • The board columns are the typical now/next/later roadmap.
  • The cards are opportunities.
  • Within the opportunity cards, I'm showing the connected solutions filtered by now/next/later
  • I've published the view to share it with a customer
Actual results
  • The published board doesn't filter correctly the solution within the next/later cards, both cards show the same solutions (see screenshot below)
  • The original board does filter correctly
Expected
  • Both published and the original board have the same result wrt filtering (see screenshot of original board below)
Could this be a bug?
John Funk
Hi Antoni,
I am not able to follow your use case very well. Is there a way to create a few test cards and then do screenshots so we can understand better?
Thanks for the reply @John Funk , I've added the screenshots in the main description above.
Like John Funk likes this
John Funk
What type of project is this? Team-managed? Company-managed? Business? Software? Are you grouping by something on the board?
It's a Jira Product Discovery project. There is no groupby, only board view with columns set to roadmap stages.
