Showing results forĀ
Search instead forĀ
Did you mean:Ā
Connection problem with MySQL 5.7: (Got an error reading communication packets)
Armen_Mkrtchyan
June 7, 2020
I have set up of Atlassian Jira, Confluence and Bitbucket using docker containers. The initial configuration was on CentOS 7. After 6 month of working without any problem recently i have restarted server and now i am getting:
[Note] Aborted connection 2 to db: 'jiradb' user: 'jira' host: '172.18.0.3' (Got an error reading communication packets)
Same true for confluence instance. I have tried different recommendations regarding above mentioned error, but no one helps.
I have tried also following which did not help:
1. Make fresh install using CentOS 8 and using latest stable release of Docker
2. Export jira database using mysqldump and load it to the new installed mysql container
Below is my configuration details:
# cat /etc/redhat-release
CentOS Linux release 8.1.1911 (Core)
# docker version
Client: Docker Engine - Community
Version: 19.03.11
API version: 1.39
Go version: go1.13.10
Git commit: 42e35e61f3
Built: Mon Jun 1 09:13:48 2020
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 18.09.1
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 4c52b90
Built: Wed Jan 9 19:06:30 2019
Experimental: false
my.cnf file:
[mysqld]
# Disabling symbolic-links is recommended to prevent assorted security risks
symbolic-links=0
character-set-server=utf8
collation-server=utf8_bin
max_allowed_packet=2048M
innodb_log_buffer_size=32M
innodb_log_file_size=2GB
query-cache-size = 8M
query-cache-type = 1
query_cache_limit = 8M
join-buffer-size = 8M
#table-cache = 1024
table-definition-cache = 1024
open-files-limit = 4096
bind-address = 0.0.0.0
transaction-isolation=READ-COMMITTED
connect_timeout = 6000
net_read_timeout = 6000
net_write_timeout = 6000
 docker-compose.yml file:
version: '3'
services:
database:
image: mysql:5.7
restart: always
container_name: mysql
volumes:
- database-data:/var/lib/mysql
- /data/mysql/my.cnf:/etc/my.cnf
networks:
- atl-net
environment:
TZ: "America/Toronto"
jira:
depends_on:
- database
image: atlassian/jira-software
restart: always
container_name: jira
volumes:
- jira-data:/var/atlassian/application-data/jira
- ./mysql-connector-java-8.0.20.jar:/opt/atlassian/jira/lib/mysql-connector-java-8.0.20.jar
networks:
- atl-net
ports:
- "8080:8080"
environment:
- TZ="America/Toronto"
- JVM_MINIMUM_MEMORY=2048m
- JVM_MAXIMUM_MEMORY=2048m
- ATL_JDBC_URL=jdbc:mysql://database:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=default_storage_engine=InnoDB
- ATL_JDBC_USER=jira
- ATL_JDBC_PASSWORD=XXXXXXX
- ATL_DB_DRIVER=com.mysql.jdbc.Driver
- ATL_DB_TYPE=mysql
- ATL_PROXY_NAME=jira.xxxx.com
- ATL_PROXY_PORT=443
- ATL_TOMCAT_PORT=8080
- ATL_TOMCAT_SCHEME=https
- ATL_TOMCAT_SECURE=true
confluence:
depends_on:
- database
- jira
image: atlassian/confluence-server
restart: always
container_name: confluence
volumes:
- confluence-data:/var/atlassian/application-data/confluence
- ./mysql-connector-java-8.0.20.jar:/opt/atlassian/confluence/confluence/WEB-INF/lib/mysql-connector-java-8.0.20.jar
networks:
- atl-net
ports:
- "8090:8090"
environment:
- ATL_JDBC_URL=jdbc:mysql://database/confluencedb?sessionVariables=default_storage_engine%3DInnoDB&useUnicode=true&characterEncoding=utf8
- ATL_JDBC_USER=confluence
- ATL_DB_TYPE=mysql
- ATL_PROXY_NAME=confluence.xxxx.com
- ATL_TOMCAT_PORT=8090
- ATL_TOMCAT_MAXTHREADS=50
bitbucket:
depends_on:
- database
- jira
image: atlassian/bitbucket-server
restart: always
container_name: bitbucket
volumes:
- bitbucket-data:/var/atlassian/application-data/bitbucket
networks:
- atl-net
ports:
- "7990:7990"
- "7999:7999"
environment:
- JVM_MINIMUM_MEMORY=1024m
- JVM_MAXIMUM_MEMORY=1024m
- JDBC_URL=jdbc:mysql://database:3306/stashdb?characterEncoding=utf8&useUnicode=true
- JDBC_USER=stash
- JDBC_PASSWORD=XXXX
- JDBC_DRIVER=com.mysql.jdbc.Driver
- SERVER_PROXY_NAME=bitbucket.xxxx.com
- SERVER_PROXY_PORT=443
- SERVER_SCHEME=https
- SERVER_SECURE=true
networks:
atl-net:
volumes:
jira-data:
driver: local
driver_opts:
type: none
device: /data/atlassian/application-data/jira
o: bind
confluence-data:
driver: local
driver_opts:
type: none
device: /data/atlassian/application-data/confluence
o: bind
bitbucket-data:
driver: local
driver_opts:
type: none
device: /data/atlassian/application-data/bitbucket
o: bind
database-data:
driver: local
driver_opts:
type: none
device: /data/mysql/mysql
o: bind
Bigger part of log file. Issued command is:
docker-compose up database jira
jira | 07-Jun-2020 07:38:07.368 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
jira | 07-Jun-2020 07:38:07.380 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 436 ms
jira | 07-Jun-2020 07:38:07.387 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
jira | 07-Jun-2020 07:38:07.387 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.50
jira | 07-Jun-2020 07:38:07.396 SEVERE [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: [/opt/atlassian/jira/conf/Catalina/localhost]
mysql | 2020-06-07T07:38:07.917100Z 0 [Note] InnoDB: Buffer pool(s) load completed at 200607 3:38:07
jira | 2020-06-07 07:38:10,243+0000 localhost-startStop-1 INFO [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory '/var/atlassian/application-data/jira' is validated and locked for exclusive use by this instance.
jira | 2020-06-07 07:38:10,293+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
jira |
jira | ****************
jira | Jira starting...
jira |
jira | 2020-06-07 07:38:10,426+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
jira |
jira | ___ Environment _____________________________
jira |
jira | JIRA Build : 8.9.0#809000-sha1:4ceb90abd8e813f4565a1705e597aeab0a82fc50
jira | Build Date : Mon May 18 00:00:00 GMT 2020
jira | JIRA Installation Type : Standalone
jira | Application Server : Apache Tomcat/8.5.50 - Servlet API 3.1
jira | Java Version : 1.8.0_252 - AdoptOpenJDK
jira | Current Working Directory : /var/atlassian/application-data/jira
jira | Maximum Allowable Memory : 1963MB
jira | Total Memory : 1963MB
jira | Free Memory : 1457MB
jira | Used Memory : 506MB
jira | Memory Pool: Code Cache : Code Cache: init = 33554432(32768K) used = 10244864(10004K) committed = 33554432(32768K) max = 536870912(524288K)
jira | Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 21014056(20521K) committed = 21626880(21120K) max = -1(-1K)
jira | Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 2348624(2293K) committed = 2490368(2432K) max = 1073741824(1048576K)
jira | Memory Pool: PS Eden Space : PS Eden Space: init = 537395200(524800K) used = 507838896(495936K) committed = 537395200(524800K) max = 537395200(524800K)
jira | Memory Pool: PS Survivor Space : PS Survivor Space: init = 89128960(87040K) used = 24311360(23741K) committed = 89128960(87040K) max = 89128960(87040K)
jira | Memory Pool: PS Old Gen : PS Old Gen: init = 1431830528(1398272K) used = 163872(160K) committed = 1431830528(1398272K) max = 1431830528(1398272K)
jira | JVM Input Arguments : -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms2048m -Xmx2048m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Djira.home=/var/atlassian/application-data/jira -Datlassian.plugins.startup.options=-fg -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Xloggc:/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=5 -XX:GCLogFileSize=20M -XX:+PrintGCDetails -XX:+PrintGCDateStamps -XX:+PrintGCTimeStamps -XX:+PrintGCCause -XX:+ExplicitGCInvokesConcurrent -Dignore.endorsed.dirs= -Dcatalina.base=/opt/atlassian/jira -Dcatalina.home=/opt/atlassian/jira -Djava.io.tmpdir=/opt/atlassian/jira/temp
jira | Java Compatibility Information : JIRA version = 8.9.0, Java Version = 1.8.0_252
jira |
jira | ___ Java System Properties _________________
jira |
jira | atlassian.plugins.startup.options : -fg
jira | atlassian.standalone : JIRA
jira | awt.toolkit : sun.awt.X11.XToolkit
jira | catalina.base : /opt/atlassian/jira
jira | catalina.home : /opt/atlassian/jira
jira | catalina.useNaming : true
jira | common.loader : "${catalina.base}/lib",
jira | "${catalina.base}/lib/*.jar",
jira | "${catalina.home}/lib",
jira | "${catalina.home}/lib/*.jar"
jira | file.encoding : UTF-8
jira | file.encoding.pkg : sun.io
jira | ignore.endorsed.dirs :
jira | java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
jira | java.awt.headless : true
jira | java.awt.printerjob : sun.print.PSPrinterJob
jira | java.class.version : 52.0
jira | java.home : /opt/java/openjdk/jre
jira | java.io.tmpdir : /opt/atlassian/jira/temp
jira | java.locale.providers : COMPAT
jira | java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
jira | java.naming.factory.url.pkgs : org.apache.naming
jira | java.protocol.handler.pkgs : org.apache.catalina.webresources
jira | java.runtime.name : OpenJDK Runtime Environment
jira | java.runtime.version : 1.8.0_252-b09
jira | java.specification.name : Java Platform API Specification
jira | java.specification.vendor : Oracle Corporation
jira | java.specification.version : 1.8
jira | java.util.concurrent.ForkJoinPool.common.threadFactory : org.apache.catalina.startup.SafeForkJoinWorkerThreadFactory
jira | java.util.logging.config.file : /opt/atlassian/jira/conf/logging.properties
jira | java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
jira | java.vendor : AdoptOpenJDK
jira | java.vendor.url : http://java.oracle.com/
jira | java.vendor.url.bug : http://bugreport.sun.com/bugreport/
jira | java.version : 1.8.0_252
jira | java.vm.info : mixed mode
jira | java.vm.name : OpenJDK 64-Bit Server VM
jira | java.vm.specification.name : Java Virtual Machine Specification
jira | java.vm.specification.vendor : Oracle Corporation
jira | java.vm.specification.version : 1.8
jira | java.vm.vendor : AdoptOpenJDK
jira | java.vm.version : 25.252-b09
jira | jdk.tls.ephemeralDHKeySize : 2048
jira | jira.home : /var/atlassian/application-data/jira
jira | mail.mime.decodeparameters : true
jira | org.apache.catalina.security.SecurityListener.UMASK : 0027
jira | org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
jira | org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
jira | os.arch : amd64
jira | os.name : Linux
jira | os.version : 4.18.0-147.8.1.el8_1.x86_64
jira | package.access : sun.,
jira | org.apache.catalina.,
jira | org.apache.coyote.,
jira | org.apache.jasper.,
jira | org.apache.tomcat.
jira | package.definition : sun.,
jira | java.,
jira | org.apache.naming.,
jira | server.loader :
jira | shared.loader :
jira | sun.arch.data.model : 64
jira | sun.boot.library.path : /opt/java/openjdk/jre/lib/amd64
jira | sun.cpu.endian : little
jira | sun.cpu.isalist :
jira | sun.io.unicode.encoding : UnicodeLittle
jira | sun.java.command : org.apache.catalina.startup.Bootstrap start
jira | sun.java.launcher : SUN_STANDARD
jira | sun.jnu.encoding : UTF-8
jira | sun.management.compiler : HotSpot 64-Bit Tiered Compilers
jira | sun.os.patch.level : unknown
jira | tomcat.util.buf.StringCache.byte.enabled : true
jira | tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-taglib*.jar,
jira | log4j-web*.jar,
jira | log4javascript*.jar,
jira | slf4j-taglib*.jar
jira | tomcat.util.scan.StandardJarScanFilter.jarsToSkip : annotations-api.jar,
jira | ant-junit*.jar,
jira | ant-launcher.jar,
jira | ant.jar,
jira | asm-*.jar,
jira | aspectj*.jar,
jira | bootstrap.jar,
jira | catalina-ant.jar,
jira | catalina-ha.jar,
jira | catalina-jmx-remote.jar,
jira | catalina-storeconfig.jar,
jira | catalina-tribes.jar,
jira | catalina-ws.jar,
jira | catalina.jar,
jira | cglib-*.jar,
jira | cobertura-*.jar,
jira | commons-beanutils*.jar,
jira | commons-codec*.jar,
jira | commons-collections*.jar,
jira | commons-daemon.jar,
jira | commons-dbcp*.jar,
jira | commons-digester*.jar,
jira | commons-fileupload*.jar,
jira | commons-httpclient*.jar,
jira | commons-io*.jar,
jira | commons-lang*.jar,
jira | commons-logging*.jar,
jira | commons-math*.jar,
jira | commons-pool*.jar,
jira | dom4j-*.jar,
jira | easymock-*.jar,
jira | ecj-*.jar,
jira | el-api.jar,
jira | geronimo-spec-jaxrpc*.jar,
jira | h2*.jar,
jira | hamcrest-*.jar,
jira | hibernate*.jar,
jira | httpclient*.jar,
jira | icu4j-*.jar,
jira | jasper-el.jar,
jira | jasper.jar,
jira | jaspic-api.jar,
jira | jaxb-*.jar,
jira | jaxen-*.jar,
jira | jdom-*.jar,
jira | jetty-*.jar,
jira | jmx-tools.jar,
jira | jmx.jar,
jira | jsp-api.jar,
jira | jstl.jar,
jira | jta*.jar,
jira | junit-*.jar,
jira | junit.jar,
jira | log4j*.jar,
jira | mail*.jar,
jira | objenesis-*.jar,
jira | oraclepki.jar,
jira | oro-*.jar,
jira | servlet-api-*.jar,
jira | servlet-api.jar,
jira | slf4j*.jar,
jira | taglibs-standard-spec-*.jar,
jira | tagsoup-*.jar,
jira | tomcat-api.jar,
jira | tomcat-coyote.jar,
jira | tomcat-dbcp.jar,
jira | tomcat-i18n-*.jar,
jira | tomcat-jdbc.jar,
jira | tomcat-jni.jar,
jira | tomcat-juli-adapters.jar,
jira | tomcat-juli.jar,
jira | tomcat-util-scan.jar,
jira | tomcat-util.jar,
jira | tomcat-websocket.jar,
jira | tools.jar,
jira | websocket-api.jar,
jira | wsdl4j*.jar,
jira | xercesImpl.jar,
jira | xml-apis.jar,
jira | xmlParserAPIs-*.jar,
jira | xmlParserAPIs.jar,
jira | xom-*.jar
jira | user.country : US
jira | user.dir : /var/atlassian/application-data/jira
jira | user.home : /var/atlassian/application-data/jira
jira | user.language : en
jira | user.name : jira
jira | user.timezone : GMT
jira |
jira | 07-Jun-2020 07:38:10.577 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
jira | 2020-06-07 07:38:10,580+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
jira | 07-Jun-2020 07:38:10.581 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
jira | 07-Jun-2020 07:38:10.598 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 3217 ms
jira | 2020-06-07 07:38:10,612+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
jira | 2020-06-07 07:38:10,614+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
mysql | 2020-06-07T07:38:11.051764Z 2 [Note] Aborted connection 2 to db: 'jiradb' user: 'jira' host: '172.18.0.3' (Got an error reading communication packets)
jira | 2020-06-07 07:38:11,061+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks.
jira | 2020-06-07 07:38:11,061+0000 JIRA-Bootstrap FATAL [c.a.jira.startup.JiraStartupLogger] Startup check failed. Jira will be locked.
jira | 2020-06-07 07:38:11,100+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
jira | ---------------------------------------------------------------------------------
jira | Heap memory : Used: 273 MiB. Committed: 1963 MiB. Max: 1963 MiB
jira | Non-heap memory : Used: 45 MiB. Committed: 67 MiB. Max: 1536 MiB
jira | TOTAL : Used: 318 MiB. Committed: 2030 MiB. Max: 3499 MiB
Armen_Mkrtchyan
June 8, 2020
Finally problem is solved! I have added following line in my.cnf file:
[mysqld]
default-time-zone
=+00:00
You can change time-zone value to the required one.
MySQL database server is configured to a time zone like, EDT, PDT, CEST, etc. These time zone values are not recognizable since JAVA 8. Most probably after some time it was updated and after restart i start getting "(Got an error reading communication packets)" .
I found solution here: https://stackoverflow.com/questions/26515700/mysql-jdbc-driver-5-1-33-time-zone-issue
Deleted user September 10, 2021
Thanks a ton, just had the same problem after upgrading Confluence 7.9.1 to 7.13.
Addind the timezone setting in the my.cnf file solved the issue for me as well.
SERVER
VERSION
8.9.0
