×Hi,
When adding comments, contact list is not shown after I type @user1603166931620, what could be the reason for this?
Hi, @Syed Haider
For this one, you need to be a part of Browse Users under Global Permissions. If the user is not part of any group under Browse users, the user cannot see the contact list.
Browse Users
Ability to select a user or group from a popup window as well as the ability to use the 'share' issues feature. Users with this permission will also be able to see the names of all users and groups in the system.
Sudhir
Thanks Sudhir, I'm checking with admin on this.
