Convert Epic Timeline View to Percentages
remi October 8, 2024
HI ,
I track my projects in the epic timeline view.
I have been asked to convert the timeline view into percentages so the business can understand what % of an epic has been worked on in a given month.
Please has anyone done this before.
Kindly help
Danut M _StonikByte_
Hi @remi,
I'm afraid that this is not possible without Advanced Roadmaps, which requires the Premium plan. Another solution would be to search for a plugin on Atlassian Marketplace that provides such capability.
If you consider the idea of using a plugin, our Great Gadgets app offers a Pivot Table & Pivot Chart gadget that can calculate % completion for your epics based on number of tasks resolved or amount of story points burned.
The result can be displayed as a table, heat-map table or charts or various types. See some examples:
Danut.
remi October 10, 2024
thank you @Danut M _StonikByte_  i'll check it out
Hi @remi,
You are welcome! If you have any questions, feel free to contact support@stonikbyte.com.
Danut.
Walter Buggenhout
October 8, 2024
Hi @remi,
The progress indicators in timeline view are not configurable in timelines on the standard plan.
In an advanced roadmaps plan (which is part of Jira Premium) these percentages can be displayed using a progress field.
Hope this helps!
remi October 9, 2024
Hi @Walter Buggenhout unfortunately we do not have the Jira Premium.
Is there any other way i can achieve this ?
Madhu_RVS
October 10, 2024
Hi @remi
If you would like to try out an add-on for this use case, pls take a look at
Issue Hierarchy
The app shows your issue hierarchy in a tree view created through Issue Links. The Issues in the tree can be in multiple projects and the app will pull out each one of them and show you a structured hierarchy. Also % completed at each parent level.
The app has multiple other features which are very useful in project tracking and management.
(Disclaimer: I work on RVS, the vendor for this app)
Register Now
