Convert PDF from with selected Custom field in Required fields order.
Kaviraj
Hi
Using Better PDF exporter for JIRA plugin, facing below issues
1. Printing all custom fields
2. Printing all custom fields in ascending order.
I thought of editing the PDF template but I did not get it.
1. PDF Template Code
2. Output of PDF form
How to achieve below points
1. To print only selected custom fields in lie of printing all custom fields
2. Printing in required order.
Levente Szabo _Midori_
December 26, 2019 edited
Hi @Kaviraj
I'm Levente from Midori, makers of Better PDF Exporter for Jira Cloud.
What do you mean by "selected custom fields" in this case?
In the Export menu, there is a "PDF" and a "PDF (All fields) option."
If you export with the "PDF" option only the currently visible custom fields will be exported.
Please reach out to our support team so we can help you customize your template further!
Kaviraj
Hi @Levente Szabo _Midori_
I have gone through the PDF template Code(Issue-fo.vm) to edit exportAllCustomFields ForLoop but i did not get it.
I just wanna edit the vm code to get output like below in a PDF form.
Consider i have 10 custom fields but i wanna print only below fields.
Custom field 01 : Value of Custom Field 01
Custom field 02 : Value of Custom Field 02
Custom field 03 : Value of Custom Field 03
Custom field 09 : Value of Custom Field 09
Custom field 07 : Value of Custom Field 07
Like • 2 people like this
