I am using Jira Software version 8.6 with Scriprunner.
Trying to write a listener that reads a single select list custom field and copies it to a number custom field of an issue.
I am getting the following error:
Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: null
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object '13' with class 'com.atlassian.jira.issue.customfields.option.LazyLoadedOption' to class 'java.lang.Double'
I am using the following code:
"New Story Points" - Single Select list
"Story Points" - Number field
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def newStoryPointsChanged = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "New Story Points"}
if (newStoryPointsChanged){
def targetField = customFieldManager.getCustomFieldObjectByName("Story Points")
def sourceField = customFieldManager.getCustomFieldObjectByName("New Story Points")
def sourceFieldValue = (Double) event.issue.getCustomFieldValue(sourceField)
def targetFieldValue = event.issue.getCustomFieldValue(targetField)
targetField.updateValue(null, event.issue, new ModifiedValue(targetFieldValue, sourceFieldValue),new DefaultIssueChangeHolder())
Can you suggest the correct way for the following line:
Rupa
Select lists hold an "option" object, not a number, so your (Double) cast is nonsense. It's a like asking something like "what number is my penguin?".
My guess is that your "New Story Points" holds options with names that are displayed to the user like "one, two, three..." or "1, 2, 3...". You'll need to convert those labels into numbers. So
def sourceFieldValueName = event.issue.getCustomFieldValue(sourceField)
def saveValue = 0
if ("one".equals(sourceFieldValueName) ) {saveValue = 1}
if ("two".equals(sourceFieldValueName) ) {saveValue = 2}
or perhaps use "parseInt" to convert the name string to a number
