Copy Single value from Multi selected Field value During Transition
Prathap DL
Hi Community,
I'm Auto creating tickets using JMWE Create issue's Post function. I have a Multi select Custom Field in Parent ticket. When i select 2 Values from the custom field and do the transition then 2 tickets will auto created and linked with parent.
I have single line Custom field in Auto created Child ticket. Now my requirement is Based on the Multi select custom field values Childs tickets are creating. Now i want Single value from Multi select field should copy to each auto created chile tickets.
Ex: Parent ticket Custom field Values: "Test 1", "Test 2", "Test 3"(3 values are selected)
Auto Child ticket 1 Custom field value: "Test 1"
Auto Child ticket 2 Custom field value: "Test 2"
Auto Child ticket 3 Custom field value: "Test 3"
Can i achieve this through JMWE Post-creation script which is there inside Create issue's Post function?
Or Please suggest any other options.
Suprija Sirikonda _Appfire_
July 22, 2024
Hi @Prathap DL,
In the JMWE Create issue(s) post-function, select the desired text field under “Set specific fields of new issue(s)” and add the below template:
{{ it }}
This will set each iterator value (the multi-select field value in your case) to the text field of each of the newly created child issue(s).
See the documentation here for more details.
 BTW, I'm from Appfire, the vendor of JMWE.
Suprija
Lead Product Support Engineer - Appfire
Prathap DL
Hi @Suprija Sirikonda _Appfire_
It worked. Thanks for the support.
FREE
