Copy attachment with issue link in two project
Andrey Miranda Diaz November 29, 2023
Can you help us with the following requirement :
We are using the clone issue link to clone tickets through a transition.
After cloning the ticket, it is required that the comments and attachment can be sent in both directions.
You can also synchronize attachments when they are added to comments .
I am trying with the following script by placing a code in script runner in a listering that is activated when I add an attachment to the parent ticket but when I add a new attachment it duplicates the ones that have been sent previously .
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.issue.attachment.Attachment
import com.atlassian.jira.issue.AttachmentManager
import com.atlassian.jira.issue.comments.Comment
import com.atlassian.jira.issue.comments.CommentManager
import com.atlassian.jira.issue.link.IssueLinkManager
import org.ofbiz.core.entity.GenericValue
//def attachmentManager = ComponentAccessor.getAttachmentManager()
//def lastAttachment = attachmentManager.getAttachments(issue).last()
//def issue = ComponentAccessor.getIssueManager().getIssueObject() //dummy issue - delete this
//String[] validLinkTypes = ["moved to", "cloned to"]
def linker = ComponentAccessor.getIssueLinkManager()
def commentMgr = ComponentAccessor.getCommentManager()
def issue = event.issue as MutableIssue
def project = issue.getProjectObject().getKey()
def issueLinks = linker.getOutwardLinks(issue.getId())
def subElements = issueLinks.findAll { it.issueLinkType.name.contains('cloned to') && it.issueLinkType.name.contains('moved to')
def newComment = event.getComment()
def originalAuthor = newComment.getAuthorApplicationUser()
def commentBody = newComment.getBody()
subElements.each {
if( commentBody != "")
commentMgr.create(it.getDestinationObject(), originalAuthor, commentBody , false)
//subElements.each {
if(lastAttachment)
attachmentManager.copyAttachment(lastAttachment, originalAuthor, it.getDestinationObject().key)
Do you have any suggestions on how to solve this requirement?
