Using ScriptRunner "Copy custom field values" function, I'm trying to copy values from a text field to a number field. I've confirmed that all issues in my filter results have a numeric value in the text field, but the script does not modify any issues. Will this ever be supported?
If I remember right, you have to cast as double. Did you try that?
Er, I should add that while I don't think this is directly supported in Scriptrunner, I've gotten around this before by making a scripted field that gets the value from the text field as a number (return (something) as Double), and then you can use the built in function to copy over the data.
Seems like a good thing to try...
Probably text to number is not supported, but as April said you can create a (Number) script field which gets the text value, and then use the built-in script to copy from the script field to the number field.
Here is code for script postfunction provided by ScriptRunner plugin
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.issue.MutableIssue import java.text.DecimalFormat CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); DecimalFormat decimalFormat = new DecimalFormat(); issue.setCustomFieldValue( customFieldManager.getCustomFieldObjectByName("number field name") , decimalFormat.parse ( (String) issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("text field name"))).doubleValue() )
