Copy custom field values using Built In Scripts is not working
Pranita Warik September 28, 2020
I created a Filter to list down the issues in which I want to copy the values from a Issue Picker Custom Field Type to Multiple Issue Picker (created via Script Runner).
Built In scripts --> Copy custom field values
On preview, I am able to view this message:
Will operate on 2 issue(s) from the Copy Custom Fields filter....
Copying source field JIRA Project Mapping to target field Jira Project Issue Picker.
But on Run:
0 issue(s) modified.
Nic Brough -Adaptavist-
September 30, 2020
The built-in copy script can only handle simple cases where the type of data in the fields is similar enough.  A single issue picker going to a multiple issue picker is not supported.
You will need to write your own bit of code to convert the data you extracted from the single picker field to the multiple-picker type.
Pranita Warik September 30, 2020
@Nic Brough -Adaptavist-
The Issue Picker Custom Field Type holds multiple values as well.
Is it conflicting because one is custom field issue picker and the other is scripted field issue picker.
As of now, I have used the import .csv file to upload the values.
September 30, 2020
You didn't say which issue picker app you were using, so I took a guess.  Either way, the objects in the two fields are not compatible.
SK March 8, 2023 edited
We are seeing "0 issue(s) modified" even when the data type is identical (number field).
Edit: Nevermind, CF scope issue.
Ty Taylor
March 23, 2023
I have the same issue. I have 2 identical Text Field (single line) fields.
Preview Returns:
Will operate on 407 issue(s) from the All MY Issues filter....
Copying source field External issue 1 to target field External issue ID.
Clicking on "Run" returns: 0 issue(s) modified.
The values are never copied over.
Mark Northcott
I am trying to copy data from one custom field to another and both are Text Field (multi-line). If I do a filter of the issues in the project I see 88 issues with content in the field but only 4 had their data copied using the ScriptRunner. Another had 352 possible but only 55 were copied.
I've noticed that the ones that were copied were at the top of the list sorted by updated date. Those that were copied had an update date of 10 June 2023 and later.
So it seems that the update date determines when the fields are copied.
SERVER
VERSION
8.5.1
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
