Anyone can help me with this. I am trying to copy the t-shirt sizing or duration into the original estimate field. The Duration are fixed value, so. I want to know if anyone know how to make this as a automation when duration is selected then it will copy that number over to original estimate
Hi @Allen Tong. Welcome to the Atlassian Community!
You can copy a numeric custom field value to the original estimate system field using Automation for Jira. What have you tried so far? If you can share your setup, we can better assist you here.
@Ivan Lima Ya i figure this out after a hour. I used the automation and schedule it based on setting the trigger as when the developer work on the workflow. Then it will use that issue of Duration and copy it into the issue of Original estimate as a numeric field by following what the duration is set.
