×I started a copy product job, and the status has been on "copying" for the past day. In details it is still exporting from my project. The estimate was 6 minutes in the copy plan.
Hi @Adam Bang
If you are struggling with moving your Jira projects between Jira Cloud instances, consider utilizing our app Deep Clone for Jira, which provides powerful cloning options and can handle complex use cases efficiently. Deep Clone can clone whole projects including their configuration and schemes between Jira Cloud instances. You can read more here.
hmm.. Is it still in progress with out any errors?
Do you find option initiate it again?
