Is it possible or an easy way to copy over a form in JSM from one org to another org? I can see you can in the same org by using the copy option to another project in the same org but I'm wondering if there's an option to go to another site. I am an Org admin in both.
I know workflow templates need to go through the marketplace also hoping to avoid that process as Its more intensive than starting from scratch.
If you are willing to use a third-party app, our Deep Clone for Jira can clone Jira Service Management issues from one Jira Cloud instance to another. You can read more on how to clone attached Jira forms here.
Nope. Atlassian stopped them from doing it.
Don't know why they go so hard on not allowing Forms to be copied across instances when it's so easy to copy them across projects, but if this wasn't buried so deep I wouldn't have gone with JSM.
You are unfortunately correct. Currently, Deep Clone for Jira can't clone Jira forms, but we are intending to add that functionality again. We can't provide a timeline yet, but this will hopefully happen soonish.
If you need the feature, you can always open a Feature Request ticket here. This helps us prioritize our feature development.
