Copying Multiple Fields via Groovy
Zachary Singh November 1, 2023
Hi All-
I am trying create a script for updating multiple issue fields from a source field to a target field in one go. We have the following already determined for our field mappings:
  • Multi Select to Single Select
  • Single Select to Single Select
  • Text to Text
  • Single User to Multi User Field
I am aware of the the build in ScriptRunner Job that allows us to utilize a filter, but we have to do it field by field and we have over 20+ fields and thousands of issues.
Any help would be great!
PD Sheehan
November 1, 2023
Is this a one-time execution? Or are you looking to have this operation repeated at a high frequency? I'm asking because you mentioned "Scriptrunner Job" which are designed to execute a specific task based on a pre-set schedule.
Either way, it doesn't much matter, the best option i, is to use the methods made available by HAPI.
Just in the Scriptrunner Console, you can use JQL and HAPI to perform a pre-determined set of field update operations on all issues.
def
jql = 'your jql to identify issues to update'
Issues.search(jql).each{issue->
    issue.update{
setSendEmail(false) //adjust as needed
setEventDispatchOption(EventDispatchOption.DO_NOT_DISPATCH) //adjust as needed
        def multiFieldOptionList = issue.getCustomFieldValue('MultiCustomField1')
        setCustomFieldValue('SingleSelect', multiFieldOptionList[0].value)
        /* ... etc for all your other mappings */
HAPI will take care of all the underlying issue updates and identifying the correct option in the new field based on the text of the option value(s) of the old field.
Zachary Singh November 2, 2023
Thanks Peter, so it doesn't seem to like the .value without passing it as string.
No signature of method: com.adaptavist.hapi.jira.fields.DumbFieldUpdater.set() is applicable for argument types: ([Ljava.lang.Object;) values: [[1.0]] Possible solutions: set([Ljava.lang.String;), get(), use([Ljava.lang.Object;), wait(), any(), grep()
PD Sheehan
November 2, 2023
Can you add and report back the output of
log.info "multiFieldOptionList result is $multiFieldOptionList (${multiFieldOptionList.getClass()})
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script92.groovy: 16: Unexpected input: '"multiFieldOptionList result is $' @ line 16, column 10. log.info "multiFieldOptionList result is $multiFieldOptionList (${multiFieldOptionList.getClass()}) ^ 1 error </pre>.
PD Sheehan
November 2, 2023
Maybe share your full script... all I supplied were example syntax. You have to adjust for your use case and field names and field types etc.
Apologies, I just took the HAPI portion that you provided and adjusted for my custom fields and jql. The test fields I was using are text from a single line to multi line.
def jql = 'issuekey=DT-13173'
issue.update{
def multiFieldOptionList = issue.getCustomFieldValue('CR #')
setCustomFieldValue('Technical Design Details', multiFieldOptionList[0].value)
PD Sheehan
November 2, 2023
Try with the log like this:
issue.update{
log.info "multiFieldOptionList result is $multiFieldOptionList (${multiFieldOptionList.getClass()}"
Unfortunately I am still getting the same error
PD Sheehan
November 2, 2023
Did you copy the full script in the last reply? I had fixed an issue with a missing double-quote.
Maybe you can include a screenshot that shows the full script and any errors.
Here is an expanded example that I was able to test in my environment (except I left out the setCustomValuePart):
def jql = '"Automatic Sub-Tasks" is not empty'
def nameOfMultiSelectField = 'Automatic Sub-Tasks'
def nameOfSingleSelectField = 'Technical Design Details'
Issues.search(jql).take(1).each{issue->
issue.update{
def multiFieldOptionList = issue.getCustomFieldValue(nameOfMultiSelectField)
log.info "$issue.key: value of $nameOfMultiSelectField is $multiFieldOptionList (${multiFieldOptionList.getClass()})"
if(multiFieldOptionList instanceof List){
log.info "$issue.key: multiFieldOptionList.firstOption = ${multiFieldOptionList[0].value}"
} else {
log.error "$nameOfMultiSelectField is not returning a list of Options. This field doesn't work for this example."
//this will attempt to lookup an option in nameOfSingleSelectField that has the same string value as the first selected option in nameOfMultiSelectField. If there are no matching options, this will fail
//setCustomFieldValue(nameOfSingleSelectField, multiFieldOptionList[0].value)
This is what it looks like when i execute:
SERVER
