Could you please help on documentation with regards to Bug workflow in Jira?
Sendil Kumar March 10, 2023
I am looking for some documentation to understand what each workflow status mean and when they can be assigned as appropriate.  Workflow details with regards to issue type 'bug'.
Kindly help me on this, please.
Nic Brough -Adaptavist-
March 10, 2023
Most of us try to define status with names that says what they are, and Atlassian does the same with its defaults.  "To do" means the issue needs something doing about, "In progress" means it is in progress, "Done" means it is done, and so on.
Status are configurable, and you don't have to use the defaults Jira gives you.  If you don't know what a status means from its name, then ask the admins who created it what it is intended for (and suggest renaming it to something more clear)
Alex Koxaras -Relational-
Hi @Sendil Kumar
You have to speak to your jira and project admins and have them tell you all about the statuses being used to all your workflows. There are some pretty straight forward statuses like "ToDo", "In Progress" and "Done", or "In Review" etc, but each company and each project manager with their team can possibly mean different things. So it's best if you talk to them and guide you through.
Mohamed Benziane
Each status will mean what you want. In Jira, you're free to create your own workflow with you own status and decide why and when you can transition an issue to a status.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
