Crashes at creating a project
Arkady Lokhovitskiy October 7, 2017
Dear Support,
just installed Jira Software 7.5.0 always crashes at creating a new project. Please, find below a stack-trace of the error:
Could you, please, advise what has to be done to fix it?
Best regards,
Arkady
Technical details
Log's referral number: 53508afe-99f2-448f-8c35-81ada5fc44db
Cause
Referer URL: http://localhost:8080/secure/Dashboard.jspa
java.lang.RuntimeException: java.lang.RuntimeException: javax.servlet.ServletException: com.atlassian.activeobjects.internal.ActiveObjectsInitException: bundle [com.atlassian.plugins.base-hipchat-integration-plugin-api]
at com.atlassian.web.servlet.plugin.DynamicAuthorizationServletForwarder.forward(DynamicAuthorizationServletForwarder.java:55) [?:?]
at com.atlassian.web.servlet.plugin.DynamicAuthorizationServletForwarder.forwardSafely(DynamicAuthorizationServletForwarder.java:83) [?:?]
at com.atlassian.web.servlet.plugin.SanitizingServletForwarder.forwardSafely(SanitizingServletForwarder.java:48) [?:?]
at com.atlassian.web.servlet.plugin.RememberingServletForwarder.forwardSafely(RememberingServletForwarder.java:75) [?:?]
at com.atlassian.web.servlet.plugin.ResolvingServletForwarder.forwardSafely(ResolvingServletForwarder.java:50) [?:?]
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingResponse.lambda$null$0(RedirectInterceptingResponse.java:50) [?:?]
at java.util.Optional.map(Optional.java:215) [?:1.8.0_102]
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingResponse.lambda$forward$1(RedirectInterceptingResponse.java:50) [?:?]
at java.util.Optional.flatMap(Optional.java:241) [?:1.8.0_102]
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingResponse.forward(RedirectInterceptingResponse.java:50) [?:?]
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingResponse.sendRedirect(RedirectInterceptingResponse.java:36) [?:?]
at javax.servlet.http.HttpServletResponseWrapper.sendRedirect(HttpServletResponseWrapper.java:138) [servlet-api.jar:?]
at
Michael Brown [Ascend]
It looks like it is trying to send a notification to your HipChat. Try disabling the HipChat add-ons. Check out this article here: https://community.atlassian.com/t5/Hipchat-questions/JIRA-HipChat-Discussions-How-to-fully-disable/qaq-p/35682 on how to disable your HipChat plugins.
Just make sure you don't have any workflows set up with triggers to HipChat. If you're working from a blank copy, you shouldn't have to worry about this.
Arkady Lokhovitskiy October 9, 2017 edited
Dear Michael,
Many thanks! Yur advise does work and solves the problem.
BR
Arkady
Register now
