×Hello everyone.
I need to know if there is a way to automate the creation of a component, at the time of creating an epic. I have the JMWE app installed on the instance, but I can do that with Jira Software's native automation as well.
My idea is to create a project and the post function of it will be to create a component with the same name as the epic, so that I can link everything related to it.
This need aims to solve item search questions.
Hi @Massaut
with JMWE Cloud, you can create a new component using a Build-your-own post-function, with a script looking like this:
{{ "/rest/api/3/component" | callJira(
verb="POST",
body= {
"name": issue.fields.summary,
"project": issue.fields.project.key
