×Hello all, i've two questions :
Is it possible to create a custom field searcher template ?
Is it possible to create an email template ?
Email template it's simple. They stored in folder - ../atlassian-jira/WEB-INF/classes/templates/email/
you can change it.
For Custom field search look this - https://developer.atlassian.com/jiradev/jira-platform/building-jira-add-ons/jira-plugins2-overview/jira-plugin-module-types/custom-field-plugin-module/how-to-add-searching-to-a-custom-field
Thanks, what is the content to put into the file to change the text in the mail ?
There are 2 folders for html and text format files. It depends on the settings of which file to use.
Template files is velocity template (https://developer.atlassian.com/jiradev/jira-platform/jira-architecture/jira-templates-and-jsps/velocity-context-for-email-templates)
For example notify about closed issue - file ../email/text/issueclosed.vm
#disable_html_escaping() #parse("templates/email/includes/issueplugins.vm") [ ${baseurl}/browse/${issue.getKey()}?page=${tabpanel-all} ] #headerTitleText($i18n.getText("template.text.issue.closed", $remoteUser.displayName, $issue.key), $remoteUser.displayName) #changes([]) #comment() #visibilityText() #parse("templates/email/text/includes/issuesummary.vm") #parse("templates/email/text/includes/footer.vm")
Ok thank you Anatoly !
Is anyone know ?
You can write your own searchers, containing their own search templates, yes. They're done as add-ons. I've only ever written ones that search my own custom field types though, so I'm not sure if it's possible to write a searcher and add it to an existing field type. I have a feeling that if you wanted your searcher to be used on a standard custom field (e.g. my-lovely-searcher as an option when setting up a standard multi-select list field), you have to hack the code for the field to tell it a new searcher is available.
Ok thanks, and for the mails ?
See Anatoly's answer.
Hello @Nic Brough -Adaptavist-
I am wondering if search template could be the solution to the problem we are facing in my company. I first tried with the behaviours of the scriptrunner plugin but it did not do the job.
Here is the issue: We are opening our Jira to external partners/customers so we created a specific project for them and restricted the rights for them. But we have a custom field listing all our products/customers and we figured out that an external user even with restricted rights can see all our products/customers thanks to the autocompletion of the custom field in the advanced searching.
This is very annoying for us. What would you advise ?
