I have a Kanban board for one of my projects, but the workflow is wrong and it was created for scrum board earlier. But we are not using the scrum board at present and we use Kanban board. I want to create a workflow which co-relates with Kanban board. How to do this task. Thanks
Hi @Gnanabaskar , so are you simply wanting to create a Kanban board or are you wanting to also edit your current workflow? What kind of project? CMP or TMP? Is this a Software or Business project? I assume Software in which case you can easily create a Kanban board based n either your project or a saved filter.
please provide more info so that we might better assist.
Its CMP / Software Project.. There's already a Kanban board exists, but the workflow doesn't seems to be right.
Earlier this CMP was using Scrum board and the current workflow was created based on Scrum board.
I want to create a new workflow which is suitable for the Kanban board that is being being used at present.
In this case what should I Do?
Do you want to change the workflow or simply the columns in the board? What exactly isn't "right"?
