Hi Team. Have a label question. Not sure if it's even possible. I need to create a label from field value. Example: I have a custom field "customer", so when I create an issue and Cusomer=XXX, then lable=XXX
With your Jira Automation feature. Try with the below:
Try to place that in issue create than issue updates. OR changes to field - value when changed for a customfield.
"update": {
"labels": [{
"add": "{{ issue.customfield_10700}}"
Update your customfield id to above.
