The "Create linked work item" button shown below seems to have disappeared?? Could this be some sort of setting on my side or was this deliberate?
Many thanks!
Hi @Lazaro Coelho
You can check a couple of things below:
Verify if you have Link Issues permission on the project (Project Settings -> Permissions).
If you have the permission, ensure "Work item linking" is enabled under Jira admin Settings -> Work Items -> Work Item features -> Work Item Linking.
Hope this helps.
Thanks Kishan, I do have linking permissions and I am able to do it, I just have to create the Jira items and then link them manually. Using the button I am now missing would just make things a bit easier
it re-appeared with no apparent reason
Thanks all for the replies
¯\_(ツ)_/¯
Thanks Ignacio, that's how I was getting to the screenshot I sent earlier but for some reason the "create linked work item" simply wasn't there. It is now, no idea why
Cheers
