I have a custom field called "Systems". In this field the reporter can choose many value.
for ex. Systems = Jira - Confluence - VLC - Teams
I want to automatically create linked issues for each value that the user had choosed in field "Systems" when he/she create the issue in the portal.
Input :
Result:
Our Aim is having different issue that we can send to different system owner to get approval on the systems.
NOTE!! I have two addons on my instance:
You can certainly do this with Automation for Jira.
Simply create a rule when a new issues is created.
Then do a series of Conditions.
If System = Jira, then create a new issue
If System = Teams, then create a new issue
It would look something like this (I used Component instead of System)
We have 300 different systems. This mean i need to create to many automation to do that and i need to make sure that when we add a new system we need to put this in automation.
I need to be able to automate that.
You are not going to be able to automation the adding of new actions in an Automation rule. That's a manual process.
