[Create Screen] Showing separated field based on another fields value
yosi hatem June 15, 2025
Hey All,
I want to show custom field from create bug screen only if different value has "X"
For example field is "Yes" than I want to show separated dropdown field
Is this possible?
Note: Not with cascading. I need this field to be separated
Thanks in advance
3 votes
Priyanka Khare
June 15, 2025
  • This isn't possible with Jira's native functionality.
  • Use ScriptRunner Behaviours to dynamically show/hide fields based on another field's value.
Priyanka Khare
June 15, 2025 edited
Let me know if it works out for you.
yosi hatem June 16, 2025
Hey Priyanka,
Thanks for your quick response. I am not familiar with Script Runner.
Any ideas how can I do it?
Priyanka Khare
June 16, 2025
yosi hatem June 17, 2025
Thanks a lot
Help us plant more trees
