Create Subtask thru API Error
Kei Ji September 26, 2021
Hi ,
I try to create a subtask with API but get the error:
Here is the code:
subtask_dict = {
"project": {
"key": "IT"
"parent":{
"key":'IT-279058'
"summary": "Testing Subtask",
"issuetype": {
"name": "Sub-task"
"reporter": {
"name": "zji"
"labels": [
"bugfix",
"blitz_test"
"components" : [{'name':'ITPurchasing-Team'}],
Error:
response text = {"errorMessages":[],"errors":{"customfield_24109":"Please enter a purchase type"}}
So I try to add the customerfield_24109 and then get another error:
subtask_dict = {
"project": {
"key": "IT"
"parent":{
"key":'IT-279058'
"issuetype": {
"name": "Sub-task"
"reporter": {
"name": "zji"
"labels": [
"bugfix",
"blitz_test"
"customfield_24109": {'name':'software'}
Error:
response text = {"errorMessages":[],"errors":{"customfield_24109":"Could not find valid 'id' or 'value' in the Parent Option object."}}
Could you please help ?
Kishan Sharma
Hi @Kei Ji Welcome to the Atlassian Community!
Here's a sample example of how I created a subtask of issue type (id 10001) "Task" under my parent of type "Epic"
URL - POST https://yourdomain.atlassian.net/rest/api/2/issue
Headers:
Content-Type: application/json
Make sure authentication is present in the header
JSON Body -
"fields": {
"project": {
"key": "FIR"
"parent": {
"key": "FIR-10"
"summary": "Sub-task of FIR-10",
"description": "Test Description",
"issuetype": {
"id": "10001"
Mohamed Adel
September 26, 2021
Hi @Kei Ji
Try that line instead
"customfield_24109": {'value':'software'}
Mohamed Adel
Thanks @Mohamed Adel  !
I now got this error:
response text = {"errorMessages":[],"errors":{"customfield_24109":"Option id 'null' is not valid"}}
I have tried more time and change the software to Software and it works !
Thank you !!!!
Like • Mohamed Adel likes this
