Create a Jira Issue from Google Sheet
Phil Walburn June 5, 2018
Im trying to write a script to create a Jira Issue, when a User fills out a GoogleForm
I keep getting the following error
here is my code
The fields Project, Summary, Description and Issue Type exist in my Workspace
Can anyone help me ?
thanks
Phil
4 votes
ERIK GAUDIN
Any one know how to use the API method instead ? This one as been anounce as "phase out" starting July 2019... so it won't work very fast.
Franz Gillmeyer
November 26, 2021
As far as I know, you can use your e-mail address as user name and generate an API Token on your Jira account that serves as password. Works for me.
Tansu Akdeniz
June 5, 2018 edited
Hi @Phil Walburn,
POST URL seems wrong. It should be like "....../rest/api/2/issue".
Here is the link; https://developer.atlassian.com/cloud/jira/platform/rest/#api-api-2-issue-post
Tansu
Thanks @Tansu Akdeniz
that fixed the problem
Morris Coyle
Hi @Phil Walburn This is something I have just started looking at however my Apps Script knowledge is somewhat limited at the moment - is there anyway you would be willing to share your code?
Sathish Kannan August 8, 2019
Hi Phil,
Can you share your brilliance, I'm struggling here because of the 401 error. can you share the code it will be much appreciated.
Kannan
SAP Automation
August 8, 2019
Kannan,
try something like this
Phil
// Set the Jira Credentials
var username = "YOUR USER NAME"; // <=========================== Set your Username here
var password = "YOUR PASSWORD"; // <=========================== Set your Password here
var UserCredentials = "Basic " + Utilities.base64Encode(username + ":" + password);
var IssueURL = "https://YOUR JIRA URL GOES HERE/rest/api/2/issue"; // <=========================== Set your Jira URL here
var IssueData = {"fields":
{"project": { "key": "ProjectCode" }, // Set the Project
"summary": Summary, // Set the Summary
"description": Description, // Set the Description
"issuetype": {"name": "Enhancement"}, // Set the Enhancement
"priority": {"name": Priority}, // Set the Priority
"customfield_xxxxx" : { "value": "Fieldvaluegoeshere"}
// Call the Jira API
var payload = JSON.stringify(IssueData);
var headers = {"Accept":"application/json",
"Content-Type":"application/json",
"Authorization": UserCredentials,
"muteHttpExceptions": "True"
var options = {"method":"POST",
"headers": headers,
"payload" : payload
var response = UrlFetchApp.fetch(IssueURL, options);
// Parse the JSON response to use the Issue Key returned by the API in the email
var dataAll = JSON.parse(response.getContentText());
var issueKey = dataAll.key
Like • 2 people like this
Hi Phil, thanks much for the quick help, it works now.
Kannan
Sathish Kannan August 9, 2019
Hi Phil,
Is there a way, such that we can create sub-task for the created Jira ticket. Can you please help on this, I'm new to the scripting.
Kannan.
Franz Gillmeyer
November 26, 2021
Does anyone know how to use information that you pull from your spreadsheet for your
var data = {"fields": ?
In general the script works. As soon as I add variables that refer to my spreadsheet it doesn't work though.
My code looks like this
