×Hi guys,
Is it possible to create a filter dropdown for Components?
It shows from Quick filter, Assignee and Sprint.
I'd like to add this new one separate from Quick Filters, because it looks a mess.
Thanks.
Please please make it happen for the cloud version too.
Any change request open with the development tram to build in this fuctionality ?
thx,
I'm interested in this too. Why hasn't it been implemented for Cloud?
+1
+1
+1000000!!!!
+1 for components filter and + 1 for fix versions filter just near quick filters and assignee.
Well not only for component but for other fields as well like project (in the case where i have like 10 projects on a maintenance board).
+1 for this feature implementation
We should probably use button "Vote" near comment instead writing +1 in response, but to strengthen the case we can do both!
Here's the Jira Cloud public facing issue that most closely relates to this request. I suggest adding your voice (and vote) to this.
+1
+1
Like
+1
+1
+1
If you're on cloud - you can't do that.
If you're on server - you can use our app - Agile Board FIlter
You'll be able to configure default searchbar fields to show component dropdown as default field
https://extensi.atlassian.net/wiki/spaces/ABF/pages/29948529/Customize+search+bar+fields
Hi!
It's impossible for Cloud to do this. But for Jira Sofware Server and Data Center, yes.
If you are fine with a marketplace app to get this data, you can try out our add-on:
Agile Filters for Jira Boards
As a user, you can create your own quick filters for the boards, work with the backlogs, and select the tags you want.
Agile Filters for Jira Boards is available on the Marketplace – you can try it!
Feel free to ask any questions if you need even more information about our app.
