Create a new linked issue but new issue ID is null
Mouna Hammoudi
September 20, 2023 edited
I would like to create a new linked issue of type feature for a super feature issue. Here is my code:
void createFeature(Issue issue, List<String> componentList){
    // Issue issue
//def issueManager = ComponentAccessor.issueManager
//def issueFactory = ComponentAccessor.issueFactory
def issueLinkManager = ComponentAccessor.issueLinkManager
//def userManager = ComponentAccessor.userManager
def authenticationContext = ComponentAccessor.jiraAuthenticationContext
def issueFactory = ComponentAccessor.getIssueFactory()
def issueManager = ComponentAccessor.getIssueManager()
def userManager = ComponentAccessor.getUserUtil()
 def currentUserObj = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
MutableIssue newIssue= ComponentAccessor.issueFactory.issue
newIssue.setProjectObject(issue.getProjectObject())
newIssue.setSummary("MOUNA CAMELIA")
newIssue.setIssueTypeId("19")
int issueLinkType= 10070
long sequence =1
long newissueTypeID= 19
long myissueID= issue.getId()
 MutableIssue newissue
newissue = issueFactory.getIssue()
//set values
newissue.setProjectObject(issue.projectObject)
newissue.setIssueTypeId("19")
newissue.setSummary("MOUNA CAMELIA")
newissue.setDescription("MOUNA CAMELIA")
newissue.reporter = issue.getReporter()
def newIssueCreated = issueManager.createIssueObject(currentUserObj, newissue)
newIssue.setDescription(issue.getDescription())
                for(String component: componentList){
                    log.warn("MOUNA CAMELIA component"+ component +" NEW ISSUE "+ newIssue)
                     log.warn("MOUNA CAMELIA Component ====="+ component+"===== myissueID ====="+ myissueID+" =====newissueTypeID ====="+newissueTypeID +" =====issueLinkType ====="+issueLinkType
                     +" =====sequence ====="+ sequence +" =====authenticationContext.getLoggedInUser() ====="+authenticationContext.getLoggedInUser()+" newIssue.getId() "+newIssue.getId())
                    issueLinkManager.createIssueLink(myissueID, newIssue.getId(), issueLinkType, sequence, authenticationContext.getLoggedInUser())
I am using this code block to create a new issue
long sequence =1
then I am using this linke to assign the new issue as a linkedissue:
The function CreateIssueLink is helping assign the new issue as a linked issue. Here is the API I am using:
The problem is that I get a null pointer exception because newIssue.getId() is null but I cannot assign an ID myselt to the new issue. How can I get the ID and have it automatically generated by Jira so I can avoid the nullpointerexception?
Mohamed Benziane
Help us plant more trees
