×Hi,
I would like to create a sub-task template with some preset variables and some flexible input fields.
Is this something I can only do if I install one of the paid applications in Jira ir is this option available in standard configuration as well? I can't find it anywhere.
Thanks in advance!
Hi @Daria Cohen
I have found a plugin that does exactly what u need:
https://marketplace.atlassian.com/plugins/com.hascode.plugin.jira-quick-subtasks
Simple and straightforward, minimum intrusion. Highly recommended.
Thanks! I'll try it out!
