Does Jira allowing creating new issue Type , for example lets call it Test Task and then configure this Task to have 'Add Tests' button in it?
If I understand your query, you want to add "Add Tests" in dropdown, right. That's not possible. On the other hand you can create "Add Tests" as a sub-task issue types.
Hi @Niru V
Creating a new "Task" issue type is not possible, as "Task" is the core,
built-in issue types that cannot be modified
However, there are alternatives to achieve the use case, with the existing "Task" issue type
Use sub-tasks for tests
alternative issue types like - Bug
Let me know if this solves your issue
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
