Create another sub task under the Sub Task
ks.hyeon October 29, 2023
In JIRA Work Management, i can create a Sub Task under Task as follows. But can't I create another sub task under the Sub Task? If I can, what should I do?
2 accepted
Joel Garner
You cannot create a Sub-task under a Sub-task, however, if you add "Epics" to your Issue Types for the project, you can create a Sub-task under a Task under an Epic.
Thank you. Another thing I'm curious about is, is it not possible to add more sub tasks after creating them with Epic?
Joel Garner
October 29, 2023 edited
You can add as many Sub-tasks as you need, but they will all fall under a Task.
Epic -> Task -> Sub-task
                         Sub-task
                         Sub-task
You cannot do Epic -> Task -> Sub-task -> Sub-task
(If you hover over the Task, the + symbol will appear)
Like • ks.hyeon likes this
Thank you so much.
Lastly, what I was curious about is the lower level Sub Task as shown below.
Joel Garner
Sorry for any confusion. All the Sub-tasks will be on the same level. A sub-task cannot have a work item below it.
Yes, I see. I understand. Thank you for your support.
Hannes Obweger - JXL for Jira
Hi @ks.hyeon
just to add to Joel's great answer: The only way to model something hierarchy levels below sub-tasks in Jira is through issue links. You can create any issue link between any two issues, so you can always do e.g. a is parent of / is child of issue link between one sub-task and another.
The problem is that Jira doesn't naturally understand such issue link as a hierarchy level, so you won't see them nested in e.g. Jira Work Management's list view. There are, however, Marketplace apps that can help with this. E.g., my team and I work on an app named JXL for Jira in which you can configure custom issue hierarchies, based on Jira's built-in parent/child relationships, and/or based on issue links. This is how it looks in action:
Best,
Hannes
ks.hyeon October 31, 2023
That's great,
i will try to apply it.
JayDee
May 24, 2024
How to parent two sub-tasks ? I can only parent from sub to Task or Story and from Task to Epic.
so @Joel Garner is completely right .
Jakkula yashwanth
December 24, 2024
Hi @Hannes Obweger - JXL for Jira
How did you set the structure above?
Hi @Jakkula yashwanth
thank you for also reaching out to our support team - we'll be working with you on this via the support ticket.
Best,
Hannes
Fer
January 11, 2025
Hello from Peru
I've recently discovered Jira's powerful Project managment features
But, I've got same question about sub-levels, on real world any develpment feature includes more and more deeper details.
So , any chance to get more subleves on future ?
Greetings from Lima
FER
Like • Anastasia Melnik likes this
Learn more
