Create branch dialog - any ways to limit repos?
azz August 10, 2021
Hi all. When I create a branch from a task, absolutely all my repositories are offered to me to choose from. This is very inconvenient: I do not need to create branches from my personal projects or projects of other customers to which I have access. Is there any way to limit this list?
Perhaps this can be done from the project settings, but I did not find such an option ...
Carlos Faddul
August 11, 2021
@azz you can access the limits of Jira/branchs in automation here: What are service limits?
I have automations with more then 65 rules/conditions wich one, the best solution was to break the rule and two (for a while), maybe this helps you in your solution.
I hope I helped you.
If this post was helpful, mark it as Accepted solutions, so you can help others who may have the same difficulties.
If your question has not been resolved, please post again with more details.
azz August 12, 2021
Unfortunately, there is no necessary functional
Register today
