×Hi
I'm looking for a solution to create epic and stories that will be added to that epic. As I'm able to create stories and epic separately via script runner that I don't know how to create epic and then stories under that epic in one script. Can you help me with that? Any advises?
Seba
Hi Sebastian,
I have an example script console script located here, which shows how to create an Epic issue and then add a story inside of it for reference to help other people with the same question.
Kristian
I got it. I forgot that I can catch response and get issue key from response.
