Create issue with REST API via oAuth2
Jens May 13, 2025
we are aggregating and analysing server logs with graylog. Now we like to create jira issues for certain events.
We like to solve this using oAuth2 access via the developer console following this instructions: https://support.atlassian.com/jira/kb/how-to-use-oauth20-in-postman-client-for-jira-cloud-apis/
Authorisation already works
But i have trouble putting the request URL together. In step 3 the documentation tells me to use a site id for the xxx in the request URL. I don't know what the site id is. I tried than using the app id from the oauth app i created in the developer console. This didn't work.
My Request Example
I substituted the xxx with the app id, as i dont know yet what a site id is.
curl --location 'https://api.atlassian.com/ex/jira/xxxxxxxx-xxxx-xxxx-xxxxxxxxxxxx/rest/api/2/project' \
--header 'Accept: application/json' \
--header 'Authorization: ••••••'
The response
"timestamp": "2025-05-13T08:41:24.618827397Z",
"status": 404,
"error": "Not Found",
"message": "No message available",
"path": "/ex/jira/xxxxxxxx-xxxx-xxxx-xxxxxxxxxxxx/rest/api/2/project"
Permissions
classic scope
- read:jira-work
- manage:jira-project
- write:jira-work
granular scope
- read:issue:jira
- write:issue:jira
- read:project:jira
- write:project:jira
- read:issue:jira-software
- write:issue:jira-software
Abdallah Khaled
May 15, 2025
Hello @Jens, It's important to mention that the site ID (also known as cloud ID or Tenant ID) is a unique identifier for your Jira cloud instance. It is not the same as the app ID you created in the developer console. You can find your cloud ID from the admin console following the steps on this page here.
Jens May 15, 2025
Hi Abdallah,
thx for the explanation. I got the site id with https://###########.atlassian.net/_edge/tenant_info
But, even with the correct site id in my request, i still get a 404 while asking for project or issue:
curl --location 'https://api.atlassian.com/ex/jira/#######-#####-####-####-##########/rest/api/2/project' \
Abdallah Khaled
May 15, 2025
I beleive you're using the incorrect API endpoint; you can rely on this page here for Jira APIs, for example, to get the Projects on your site:
https://xxxx.atlassian.net/rest/api/3/project, using your site name
Jens May 15, 2025
Using https://xxxx.atlassian.net/rest/api/3/project with oauth2 Authentification gets me an 401 Unauthorized
The documentation i used https://support.atlassian.com/jira/kb/how-to-use-oauth20-in-postman-client-for-jira-cloud-apis/ states in step 3 this structure for the REST URL: https://api.atlassian.com/ex/jira/xxxxxxxx-xxxx-xxxx-xxxxxxxxxxxx/rest/api/2/project
Abdallah Khaled
May 15, 2025
Aha, I tested as well with OAuth 2.0 token following the same steps and I was able to get the projects:
Make sure that you add the Authorization header as Bearer <token>.
Jens May 15, 2025
When i am accessing the API with  https://api.atlassian.com/ex/jira/xxxxxxxx-xxxx-xxxx-xxxxxxxxxxxx/rest/api/2/project the authentification is successful.
The Problem is that i can't access any ressources. Maybe i did something wrong with the permissions?
Jens May 26, 2025 edited
Hi, i now tried using REST Access with an API Key. First a used the same scopes as with the oauth 2 approach. That gets me an 404. Then i tried the deprecated API Key without scopes. And that gets me data. So there is something wrong with my scopes.
This works with API-Key without scopes:
POST https://#######.atlassian.net/rest/api/3/issue/
Authorization: Basic ##########
Content-Type: application/json
"fields": {
"project":{
"id":"#####"
"summary": "Main order flow broken",
"issuetype": {
"id": "10001"
Jens May 30, 2025
There seems to be a maybe related bug issue here: https://jira.atlassian.com/browse/JRACLOUD-94545
Help us plant more trees
