Create issue with matching context in active rapid board?
Jakob Rödström
I want to be able to click "Create issue" when I am in a Rapid Board, and automatically fill in the fields in the create issue dilaouge to match the current filter in the rapid board.
Is this possible? Right now, I have to pre-fill about 5 fields for every new issue. (Component, Lable, Version etc.)
boardtc
November 11, 2012
There is no option for single issue created but if you are creating multiple items, fill in the 5 fields, then if you select the Create another option it will clone al the field fields for the next one which you can edit before you click Create.
